This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to remove and replace a shattered rear glass panel, or to change the color of the panel, for the Google Pixel XL.
Heat an iOpener and apply it to the phone's back glass panel for two minutes.
When the glass is warm to the touch, apply a suction cup close to the edge.
Lift on the suction cup and insert an opening pick in the gap.
Use the opening pick to slice through the glass panel's perimeter adhesive.
If the slicing becomes hard, reapply heat to the panel.
When you free the back glass around the fingerprint sensor, press down on the sensor firmly until it separates from the back glass.
Continue to slice through the adhesive underneath the back glass until you are able to remove the panel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use an opening pick and tweezers to carefully pry up and remove the mesh.
Use a spudger or opening tool to scrape all adhesive from the frame.
Use high concentration isopropyl alcohol (over 90%) to wipe away any remaining residue.
Peel the white backing away from the included adhesive sheet, making sure to punch out all cutouts.
Line the bottom edge of the adhesive to the bottom edge of the replacement glass panel.
Slowly lower the adhesive onto the glass panel.
Rub your fingers against the adhesive to help it bond with the glass panel.
Use a spudger or your finger to firmly press on the lens from the outward-facing side (the side you can usually see on the phone) of the glass panel until it loosens from its recess.
Remove the lens and transfer it onto the back side of the replacement panel.
Peel the liner off of the adhesive-backed glass panel.
Align the glass panel to the bottom edge of the indentation.
Lower the glass panel into place.
To help the back glass adhesive bond more securely, stack some heavy books on top of the phone for 30 minutes.
Repair didn’t go as planned? Check out our Google Pixel XL Answers community for troubleshooting help.
crwdns2935229:016crwdne2935229:0
thank for this tutorial. I’ve used an halogen lamp to heat the phone
