Google Pixel Slate Motherboard Replacement
  1. Google Pixel Slate Motherboard Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement, Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
    The tool and suction does not work for me. The adhesive is too strong.
    beep - crwdns2934203:0crwdne2934203:0
    It’s so easy to crack the screen here. I recommend using heat to soften the bond and avoid cracking the screen. Ideally a heating pad ($$$), but a heat gun or hair dryer also does the trick. I’ve seen a temperature range of 80-90 C (matching specs from a heating pad). I heated a pizza stone to temperature to make a homemade heating pad. That worked to soften the adhesive here.
    The adhesive is very strong, and they are not just at the edge. Some of them a little further inside, and be careful not to cut the speak grill.
    Kings Lee - crwdns2934203:0crwdne2934203:0
  2. Google Pixel Slate Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
    Where can I source the screen?
    Brandon Price - crwdns2934203:0crwdne2934203:0
  3. Google Pixel Slate Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the screen is removed, remove the two black, adhesive strips.
  4. Google Pixel Slate Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the two black screws that are holding down the copper strip.
  5. Google Pixel Slate Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the T3 Torx screwdriver to remove the seven 3mm screws.
    • Use a T2 Torx screwdriver to remove the pink 2mm screw closest to the edge.
    • There is a total of four blue 3mm screws, two black 3mm screws, one pink 3mm screw, and one pink 2mm screw holding down the plate.
  6. Google Pixel Slate Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Slate Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the metal plate.
  7. Google Pixel Slate Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two speaker plugs, one battery plug, and disconnect the four flat wires from the motherboard.
    • Nylon Tipped Tweezers may be necessary to remove the wires effectively.
    I then start removing the battery from this step. The battery adhesive is very strong. I think I have punctured the battery during removal.
  8. Google Pixel Slate Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the two silver screws.
    • Remove the 4 exposed washers from the motherboard and put aside.
  9. Google Pixel Slate Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the iFixit opening tool to remove the motherboard from the device.
Spencer Alonge
crwdns2935283:004/18/19crwdne2935283:0
669 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G5, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S2-G5, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S2G5
Very helpful, nice and clear steps.
Eddie Lundberg - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,905
