Use this guide to remove and replace the front-facing camera of your Google Pixel Slate.
Orient the Google Pixel Slate so that the screen is facing upwards.
Use the iFixit opening tool to separate screen from main body.
Use the suction cup to remove the screen from the body of the device.
Gently disconnect the three flat-wires from the screen.
Carefully separate and remove the screen from the body of the device.
Once removed, place the screen face down.
Peel back the black, adhesive strip covering the front camera so that the silver plate is exposed.
Hold back the adhesive tape to expose the two black 2mm screws that are holding down the cover plate.
Use the T2 Torx screwdriver to remove the two 2mm screws.
Once the two 2mm screws are removed, lift and remove the cover plate.
Pull upwards on the flat wire to remove the front-facing camera from the device.
Do you offer the cable that runs from the camera to the tablet motherboard or the front facing camera with cable?
The tool and suction does not work for me. The adhesive is too strong.
beep - crwdns2934203:0crwdne2934203:0
It’s so easy to crack the screen here. I recommend using heat to soften the bond and avoid cracking the screen. Ideally a heating pad ($$$), but a heat gun or hair dryer also does the trick. I’ve seen a temperature range of 80-90 C (matching specs from a heating pad). I heated a pizza stone to temperature to make a homemade heating pad. That worked to soften the adhesive here.
The adhesive is very strong, and they are not just at the edge. Some of them a little further inside, and be careful not to cut the speak grill.
Kings Lee - crwdns2934203:0crwdne2934203:0
