Use tweezers, or your fingers, to remove the old flip battery adhesive from the frame.
Apply isopropyl alcohol (>90%) and use a coffee filter or microfiber cloth to clean any adhesive residue.
Place the flip battery cable and connector adhesives over the frame, using the white outlines to confirm their orientation.
Peel the adhesive strips off their liners and place them over their respective spots on the frame.
Use the flat end of a spudger, or your fingers, to press down on the adhesive strips to adhere them to the frame.
Peel the main flip battery adhesive strip from its clear liner.
Align the top edge of the adhesive strip with the top edge of the battery recess.
Lay the adhesive strip on the frame.
Use the flat end of a spudger, or your fingers, to press down the individual adhesive strips to adhere them to the frame.
Use the pull tab to peel the colored liner off to expose the adhesive.
Peel off the colored liners on the flip battery cable and connector adhesive.
Align the top edge of the flip battery with the top edge of the battery well.
Lay the battery over the frame.
Press down along the perimeter of the flip battery to adhere it to the frame.
Press down the flip battery cable and its connector to adhere it.
Let the phone sit for an hour for the adhesive to cure.
