Google Pixel 7 Camera Glass Replacement
  1. Google Pixel 7 Camera Glass Replacement, Camera Glass: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the camera glass with a hair dryer to soften the adhesive.
  2. Google Pixel 7 Camera Glass Replacement, Remove the Damaged Glass: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a knife, carefully remove the broken glass covering the camera sensors.
    • After removing all glass, carefully clean the camera lenses with a microfiber cloth. Be cautious of any glass fragments that may remain.
  3. Google Pixel 7 Camera Glass Replacement, Insert the Replacement Glass: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7 Camera Glass Replacement, Insert the Replacement Glass: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Beware that replacement of the glass can cause many problems, specifically with the new adhesive clouding up pictures.
    • Insert the new glass with the adhesive side up (unfortunately, if the adhesive layer faces the camera, the image will be blurry).
  4. Google Pixel 7 Camera Glass Replacement, Apply Full-Surface Protective Glass Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put on a full-surface glass protector. Make sure that no dust collects between the cover and the device/camera glass.
Follow the steps in reverse order to reassemble your device
crwdns2935229:010crwdne2935229:0
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Peter Schneider
crwdns2935283:012/23/22crwdne2935283:0
389 crwdns2915208:0crwdne2915208:0
crwdns2947412:010crwdne2947412:0
Moin, könntest du mir nen link zukommen lassen wo du das Kameraglas her hast?
Florian Haß - crwdns2934203:0crwdne2934203:0
Hi, beide Gläser sind von Amazon, leider ist das untere, passende Glas momentan nicht lieferbar. Zudem habe ich leider feststellen müssen, dass die Klebeschicht die Qualität negativ beeinflusst. Ich versuche aktuell die Schicht zu entfernen, habe aber noch kein geeignetes Mittel gefunden.
https://www.amazon.de/dp/B0BJFHYFFR?ref=...
https://www.amazon.de/dp/B0BFKDFLZG?ref=...
Peter Schneider -
I did find a link on Amazon (Canadian one) that had the actual lense. It also states in the ad that it doesn't involve taking apart my phone, just do what you did in a sense. I'll post the link for you to check it out if you can and would like to. I'll update you on how it goes for me.
Pixel 7 Glass Lense Replacement Part
Mandie Thomson - crwdns2934203:0crwdne2934203:0
It is a big issues. I am also facing same problem I can't replace it because in my country there is no pixel store .
Sushan Khadka - crwdns2934203:0crwdne2934203:0
So are you saying that I take the oval glass and place it adhesive up (not down, adhering it to the phone) and then cover with a larger rear screen protector, such that the adhesive holds the oval glass to the inside of the larger screen protector?
I have tried replacing the oval glass by itself with the adhesive down to hold the oval glass to the phone without the larger rear screen protector and the lens will not focus on distance items, i.e. appear blurry as you indicate.
Gerald Biehle - crwdns2934203:0crwdne2934203:0
Thank you for sharing. Was useful to see under the glass before I started. Like similar comments, I was lucky enough to find the exact glass now on eBay but simple fix
Joe Howard - crwdns2934203:0crwdne2934203:0
I was also able to find a proper glass replacement with the adhesive attached to the back so I just used the hair dryer to heat, used a razor blade to remove the broken lens, then cleaned with 90% isopropyl alcohol on a q tip to remove the remaining adhesive followed by a eyeglass cleaning cloth on the lenses. I checked the camera and video before applying the new lens to make sure there were no spots.
BE CAREFUL of glass shards flying (I wore eyeglasses to protect myself) and if you have to turn the hair dryer on again during the process remove any loose glass shards first from the phone and your work surface. Work on a piece of paper/cardboard to contain the shards. Another option would be to use the heat pack ifixit has with their kits rather than a hair dryer to avoid shards of glass flying around.
Amanda B - crwdns2934203:0crwdne2934203:0
someone else asked the same question but i'm not sure what is meant in step 3 saying install the replacement glass, adhesive side up. how would that work?
Andrew Gresbach - crwdns2934203:0crwdne2934203:0
Funktioniert einwandfrei! Die Klebeschicht an dem Ersatzglas lässt sich gut durch einlegen in Wachbenzin entfernen. Einfach 30 Minuten das Glas in Benzin einlegen und dann kann man die Klebefolie abziehen.
Hubert Schmidt - crwdns2934203:0crwdne2934203:0
There are also replacement pieces already - you don't need to buy and misuse the "protector": https://www.ebay.de/itm/396619392186
Maximilian Riegler - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 43
crwdns2936753:07crwdne2936753:0 267
crwdns2936753:030crwdne2936753:0 1,154
crwdns2942667:0crwdne2942667:0 42,061
