Google Home Mute Button Switch Replacement
crwdns2869540:0crwdne2869540:0: 1,5K
3
20
67
1.536
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: 10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
This guide will teach you how to replace a faulty mute button switch in your Google Home with a new one.
    1. Google Home Mute Button Switch Replacement, Interconnect Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Home Mute Button Switch Replacement, Interconnect Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Home Mute Button Switch Replacement, Interconnect Cable: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
      • Pull off the Google Home’s magnetically attached base and set it aside.
      • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
      • After all four screws are out, pop the lid off the device to open the capsule.
    2. Google Home Mute Button Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully remove the interconnect cable using a pair of tweezers.
    1. Google Home Mute Button Switch Replacement, Mute Button Switch: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Home Mute Button Switch Replacement, Mute Button Switch: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
    2. Google Home Mute Button Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Home Mute Button Switch Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
      • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
Gabe Hyun
crwdns2935283:004/17/18crwdne2935283:0
847 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S24-G11, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S24-G11, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S24G11
crwdns2936753:030crwdne2936753:0 67
crwdns2959996:0crwdne2959996:0 1,536
