A guide to replace the speaker for Google Home Mini.
Place device on a flat surface.
Remove the rubber bottom as per the Google Home Mini teardown guide.
Remove the four 7mm T6 Torx screws from the bottom.
Remove the lower half of the device.
Black ribbon cable broken. Is there any chance to fix it. Please help. Thank you
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
What if this breaks off. Can i direct connect power.
Where to buy it please tell please
Remove the four 7.8mm T8 Torx screws.
Using your fingers, disconnect the wires.
crwdns2935229:08crwdne2935229:0
HI There I only have 2 lights on the google mini - and although it was working yesterday - with all 4 lights - it most certainly isn't now? I am not sure why and I am not sure what has happened?
Okay, but where can one obtain a spare speaker?
This how to is kind of pointless if you don't let us know where to obtain a speaker.
