A guide to disassemble Google Home Mini for further repairs.
Place device on a flat surface.
Remove the rubber bottom as per the Google Home Mini teardown guide.
Remove the four 7mm T6 Torx screws from the bottom.
Remove the lower half of the device.
Black ribbon cable broken. Is there any chance to fix it. Please help. Thank you
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
What if this breaks off. Can i direct connect power.
Where to buy it please tell please
crwdns2935229:014crwdne2935229:0
How did you get the rubber base off of it?
There’s a little more explanation here
