Fix the lights on the top of your Google Home with a new LED Board.
This guide will teach you how to take apart your Google Home to remove a faulty LED Board and replace it with a new one.
Pull off the Google Home’s magnetically attached base and set it aside.
Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
After all four screws are out, pop the lid off the device to open the capsule.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Carefully remove the interconnect cable using a pair of tweezers.
Use a metal spudger to pry the LED board away from the lid.
Remove the LED board.
