Google Cr-48 Chromebook Bottom Casing Replacement
    1. Google Cr-48 Chromebook Bottom Casing Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Cr-48 Chromebook Bottom Casing Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Cr-48 Chromebook Bottom Casing Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To take out the battery, slide the switch on the bottom of the laptop.
      • The battery should then pop out and you can remove it.
    1. Google Cr-48 Chromebook Bottom Casing Replacement, Bottom Casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Cr-48 Chromebook Bottom Casing Replacement, Bottom Casing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
    2. Google Cr-48 Chromebook Bottom Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Cr-48 Chromebook Bottom Casing Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Cr-48 Chromebook Bottom Casing Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
      • Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
    3. Google Cr-48 Chromebook Bottom Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Cr-48 Chromebook Bottom Casing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Cr-48 Chromebook Bottom Casing Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
      • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
Robert McLaughlin
crwdns2935283:009/09/14crwdne2935283:0
471 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 2-2, Bruce Fall 2014 crwdns2935289:0CSU Fullerton, Team 2-2, Bruce Fall 2014crwdne2935289:0
CSUF-BRUCE-F14S2G2
crwdns2935297:030crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,191
