Goodman Furnace Blower Motor Replacement
  1. Goodman Furnace Blower Motor Replacement, Opening the Unit: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Goodman Furnace Blower Motor Replacement, Opening the Unit: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Goodman Furnace Blower Motor Replacement, Opening the Unit: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Ensure all power cables are disconnected from the unit and/or wall prior to attempting this guide.
    • Gloves are highly recommended to avoid injuries from any sharp edges.
    • Unscrew the two screws located on the rear side of the unit.
    • Remove the doors and set them aside.
    • A 3/8" screwdriver will be the easiest method of completing this step.
  2. Goodman Furnace Blower Motor Replacement, Removing Electrical Connections: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Goodman Furnace Blower Motor Replacement, Removing Electrical Connections: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Goodman Furnace Blower Motor Replacement, Removing Electrical Connections: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • It is strongly advised that you take a picture of the wire configuration prior to removal for reference when connecting the new motor.
    • Disconnect the brown wire from the top of the motor.
    • Disconnect the second brown wire from the bottom of the unit.
    • Remove the white, blue, red, orange, and black wires from the controller board.
  3. Goodman Furnace Blower Motor Replacement, Removing the Motherboard Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Goodman Furnace Blower Motor Replacement, Removing the Motherboard Screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew both screws connected the motherboard to the cylindrical motor container.
    • The screws are located on top and bottom sides of the plate holding the motherboard.
  4. Goodman Furnace Blower Motor Replacement, Removing the Motor Container: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Goodman Furnace Blower Motor Replacement, Removing the Motor Container: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the cylindrical motor housing from the unit.
    • There are two screws located at each side of the top corner of the container.
    • Grab the motor container with two hands and pull it out of the unit.
    • Place the motherboard to the side.
  5. Goodman Furnace Blower Motor Replacement, Removing the Motor from the Housing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Goodman Furnace Blower Motor Replacement, Removing the Motor from the Housing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Goodman Furnace Blower Motor Replacement, Removing the Motor from the Housing: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the motor container on its side, with the wires pointing up.
    • Unscrew the 3 screws attaching the motor to the housing.
    • Take the yellow wire out of the screw.
    • Use a wrench to remove the bolt from the shaft of the motor, located on the opposite side.
    • If rust has accumulated on the motor shaft, you may wish to use sandpaper to remove it to make the motor easier to remove.
    • Firmly grasp the motor from the side where the screws were previously located and pull to remove it.
    • The white label on the side of the motor contains the model number of the blower motor which you may use as a reference when ordering a replacement, if necessary.
  6. Goodman Furnace Blower Motor Replacement, Inserting the Replacement Motor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Goodman Furnace Blower Motor Replacement, Inserting the Replacement Motor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the new motor into the motor housing.
    • Ensure the wires are at the front of the assembly.
    • Tighten the bolt at the shaft of the motor that you removed in the previous step.
    • You may wish to get the bolt started with your hands, and finish tightening with the wrench.
    • Ensure the flat surface is aligned with the screw hole prior to tightening with the wrench.
  7. Goodman Furnace Blower Motor Replacement, Reassembly Tips: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure the fan blades are freely spinning prior to continuing.
    • When assessing the fan blade, ensure you either keep your hands flat or wear gloves to avoid injury.
    • Utilize your reference photo when rewiring the unit.
Ryan W
crwdns2935283:011/30/23crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 172
crwdns2942667:0crwdne2942667:0 1,679
