The propellers are a very common broken part due to their relative fragility on a drone. Luckily, it is a very easy replacement, and the drone even comes with a few spares. The GoPro Karma wrench is a tool that comes with the drone to hold the motor in place to remove the propellers. Spare ones can be bought on ebay but are not available for purchase from the GoPro site.
Hook your fingers on the tab and pull out the battery.
Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
Remove the stabilizer by pulling the entire stabilizer out of the drone body.
The front right and back left propellers unscrew clockwise.
The front left and back right propellers unscrew counterclockwise.
Place the GoPro Karma wrench on the motor.
Hold the motor in place with the wrench and unscrew the propeller in the indicated direction.
You got it the wrong way around, to take them off you need to do the exact opposite to what you say.
hi, i am trying to fix my Karma. I have to remove the propellers but it is like they are stocked.
I try to unscrew the propellers but i can’t remove them.
Do you know what to do in this case?
