crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Hook your fingers on the tab and pull out the battery.
Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
Remove the stabilizer by pulling the entire stabilizer out of the drone body.
Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
Push with your thumb and pull up with your fingers to remove the landing gear.
Flip over the landing gear and locate the cable connector.
Use your thumbnail to disconnect the cable and free the landing gear.
Remove the two 1.2 cm long hex screws with a Hex 2.0 screwdriver and set them aside.
Remove both locked connectors by pushing the connector release tool into the hole in the center and pulling up with the white handles.
If you do not have a connector release tool, use a small screwdriver to push each tab while pulling up with the white handles.
Remove the cover plate by pulling up on the side.
Feed each connector through the hole and set aside the cover plate.
Loosen the 2 cm long hex screw in the arm with a Hex 2.0 screwdriver.
Pull up and off the broken arm.
