GoPro Karma Arms Replacement
    1. GoPro Karma Arms Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Hook your fingers on the tab and pull out the battery.
    1. GoPro Karma Arms Replacement, Stabilizer: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Karma Arms Replacement, Stabilizer: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Karma Arms Replacement, Stabilizer: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
      • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
    2. GoPro Karma Arms Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
    1. GoPro Karma Arms Replacement, Landing Gear: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the drone upside down with the landing gear out.
      • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
    2. GoPro Karma Arms Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push with your thumb and pull up with your fingers to remove the landing gear.
      • Caution: The landing gear is connected by a thin cable so do not pull too far away.
    3. GoPro Karma Arms Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Karma Arms Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip over the landing gear and locate the cable connector.
      • Use your thumbnail to disconnect the cable and free the landing gear.
    1. GoPro Karma Arms Replacement, Arms: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 1.2 cm long hex screws with a Hex 2.0 screwdriver and set them aside.
    2. GoPro Karma Arms Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Karma Arms Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove both locked connectors by pushing the connector release tool into the hole in the center and pulling up with the white handles.
      • The connector release tool is only included with the purchase of a replacement arm from the GoPro website.
      • If you do not have a connector release tool, use a small screwdriver to push each tab while pulling up with the white handles.
    3. GoPro Karma Arms Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Karma Arms Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Karma Arms Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the cover plate by pulling up on the side.
      • Feed each connector through the hole and set aside the cover plate.
    4. GoPro Karma Arms Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Karma Arms Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Loosen the 2 cm long hex screw in the arm with a Hex 2.0 screwdriver.
      • The screw will not come out but loosen it until it can rotate easily.
      • Pull up and off the broken arm.
Kyle Hoff
crwdns2935283:004/23/18crwdne2935283:0
141 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S25-G14, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S25-G14, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S25G14
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 2,775
