In this guide, you will be separating the motherboard assembly from the back housing. The GoPro Hero5 Black is waterproofed with plenty of adhesives. By completing this guide, you will have to remove the adhesive and your GoPro will no longer be waterproof.
While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
Grab the plastic flap on the battery and pull the battery out.
Pull and twist the lens cover right or left until it pops off.
レンズを回すには爪などをレンズカバーと本体との隙間に入れて、手前に引き出してから回転させます。
Go around the gap between the lens cover and camera body with a thin spludger to open a small gap and the cover will twist off easily.
Refer to the iOpener instructions for how to heat up and use the iOpener.
Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
Starting with the edges, use the spudger to pry off the faceplate.
Remove the six T3 Torx screws.
Where can I get the screw driver
Mine are actually T4 screws.
Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
Little FYI ; pry slightly on the side with the LCD. Once it pops, work the other slightly. Then pull the board up and out but remember the cables. THE PICTURE ABOVE WHERE THE METAL SHIELD IS IS THE CAMERA LENS! CABLES ARE ON THE SIDE WHERE YOU BEGIN PRYING.
Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
Does anyone know which are the specs of the connector/socket? Thanks
crwdns2935229:016crwdne2935229:0
Where can you get replacement rear screens for this
Hi, how i reset firmware in this gopro? I have a problem with a bucle starting and it dont turn on, always restarting.
