GoPro Hero3+ Silver Edition Camera Lens Replacement
    1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push the tab on the back of the device left to remove the plate covering the battery.
    2. GoPro Hero3+ Silver Edition Camera Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the strip of tape on the battery to remove the battery from the housing.
    1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Front Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert a plastic opening tool in between the front face plate and the black housing.
      • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
    2. GoPro Hero3+ Silver Edition Camera Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
      • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
    1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
      • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
      • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
    2. GoPro Hero3+ Silver Edition Camera Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero3+ Silver Edition Camera Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
    3. GoPro Hero3+ Silver Edition Camera Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
    4. GoPro Hero3+ Silver Edition Camera Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero3+ Silver Edition Camera Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry off the last ribbon cable with a plastic opening tool.
      • Remove the image sensor from the motherboard.
    1. GoPro Hero3+ Silver Edition Camera Lens Replacement, microSD/Expansion Port Assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your screwdriver, unscrew three 4mm PH00 screws that will free the metal plate.
      • A small plate will become separated when the rightmost screw is removed. Just place it to the side.
    2. GoPro Hero3+ Silver Edition Camera Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero3+ Silver Edition Camera Lens Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the plastic opening tool to pry off the referenced ribbon cable from the motherboard.
      • The microSD and Accessory Board is now ready for removal.
    1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
    2. GoPro Hero3+ Silver Edition Camera Lens Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero3+ Silver Edition Camera Lens Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero3+ Silver Edition Camera Lens Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
      • Gently remove the motherboard from the midframe using tweezers.
      • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
    1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Camera Lens: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your PH00 screwdriver to remove the last three screws from the mid frame. This will release the lens housing from the mid frame.
    2. GoPro Hero3+ Silver Edition Camera Lens Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully remove the lens from the font housing.
crwdns2935229:09crwdne2935229:0
Patrick Cook
crwdns2935283:010/01/15crwdne2935283:0
699 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-8, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 5-8, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S5G8
crwdns2942667:0crwdne2942667:0 2,623
