GoPro Hero Motherboard Replacement
  1. GoPro Hero Motherboard Replacement, Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the white plastic piece from the motherboard.
Zoe Tuggle
crwdns2935283:004/01/15crwdne2935283:0
179 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-2, Lancaster Spring 2015 crwdns2935289:0Cal Poly, Team 12-2, Lancaster Spring 2015crwdne2935289:0
CPSU-LANCASTER-S15S12G2
crwdns2935297:018crwdne2935297:0
So after doing all theses steps did it resolve the problem
Anita - crwdns2934203:0crwdne2934203:0
Thanks so much I really needed this guide.
Thanks, Sam
Sam Liam Matthews - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 10,796
