Unclip the black latch to the camera case and open the case.
Gently pry the back open by inserting a metal spudger between the case and back panel.
Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
Carefully remove the motherboard and white plastic piece from the case.
Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
Remove the two screws located on each side of the board with a Phillips screwdriver.
Separate the daughter board from the white plastic piece.
crwdns2935229:05crwdne2935229:0
Wo kann ich ein daughterboard kaufen habt ihr da was für mich?
Lukas Blohm - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
bravo! è scritto molto bene ed è stato utile. ma dove trovo il ricambio? non ci riesco!!!
michele - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Terrific guide. Does anyone know where to buy the “daughter board”?
fedebossert - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
fedebossert - 05/27/20
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a>
pavan kalyan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
