GoPro Hero 9 and 10 Black Disassembly
  1. GoPro Hero 9 and 10 Black Disassembly, PLEASE NOTE !!!!: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • WARNING: REMOVE BATTERY AND ALL POWER SOURCES BEFORE BEGINNING WITH THE DISASSEMBLY
    • GoPro Hero 9 & 10 Black were not made to be disassembled
    • In the picture below, the GoPro Hero 9 is completely disassembled.
    • Since GoPro Hero 9 Black and GoPro Hero 10 Black are almost identical, the disassembling process is the same
    • Please note that you have to cut into the back of your camera and that it will not look the same as it did before.
    • Your camera may not be waterproof after reassembly. Suggested use of waterproof housing if your camera is required to be waterproof
  2. GoPro Hero 9 and 10 Black Disassembly, Removing rear screen - part 1: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Removing rear screen - part 1: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Removing rear screen - part 1: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Preheat GoPro (avoid directly heating the screen). Heat up your GoPro to the level that you can still touch it with bare hands.
    • Cut into the side with precision knife approximately 5mm.
    • Recommend heating up the blade of precision knife for easier rear screen removal
  3. GoPro Hero 9 and 10 Black Disassembly, Removing rear screen - part 2: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Removing rear screen - part 2: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Removing rear screen - part 2: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • De-attach both screen cables
    • Remove rear screen cable extension and black plastic cable
  4. GoPro Hero 9 and 10 Black Disassembly, Battery cage removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Battery cage removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Battery cage removal: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the battery cage you will first need to remove three philips head screws
    • Lift the battery cage and disconnect the cable from the motherboard
  5. GoPro Hero 9 and 10 Black Disassembly, Charging port removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Charging port removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First disconnect power cable
    • Apply pressure with a pry tool from the position as shown in the second picture (It should come out with minimum force)
  6. GoPro Hero 9 and 10 Black Disassembly, Plastic bracket removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Plastic bracket removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove black plastic cable
    • Remove two philips head screws
  7. GoPro Hero 9 and 10 Black Disassembly, Camera removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Camera removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect camera cable
    • Remove three screws as shown in the picture
  8. GoPro Hero 9 and 10 Black Disassembly, Motherboard removal - part 1 (cables): crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Motherboard removal - part 1 (cables): crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect all remaining cables
  9. GoPro Hero 9 and 10 Black Disassembly, Motherboard removal - part 2: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Motherboard removal - part 2: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Motherboard removal - part 2: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove three philips head screws
  10. GoPro Hero 9 and 10 Black Disassembly, Record button pcb removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four philips head screws
  11. GoPro Hero 9 and 10 Black Disassembly, Power button with support bracket removal: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the power button with its support bracket, you will have to twist the thing to the side and then pull. After all the steps taken above, it is only held on by a plastic pin
    • When reassembling, you will probably have to apply glue where the plastic pins were, or you will not be able to press the power button
  12. GoPro Hero 9 and 10 Black Disassembly, Speaker removal: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the speaker, I recommend using a thin prying tool to pry from the side and it will pop right out
    • When reinserting the speaker you may need to apply some glue (recommend E6000)
  13. GoPro Hero 9 and 10 Black Disassembly, Mounting bracket + Lens cover removal: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Mounting bracket + Lens cover removal: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove GoPro mounting bracket you have to remove four TX 5 screws
    • When removing lens cover you will have to twist counter clock wise. It can require more strength if you are removing it for the first time
  14. GoPro Hero 9 and 10 Black Disassembly, Metal roll cage removal: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Metal roll cage removal: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Metal roll cage removal: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, remove four TX4 screws from the front of the GoPro
    • Then remove one TX4 Screw from the inside of the GoPro as shown in the picture
    • In some occasions, you can remove the cage by applying enough force from the front of the GoPro where the lens cover was, but in my case i had to use a precision knife to chip away four melted plastic pins for easier removal and then apply force
  15. GoPro Hero 9 and 10 Black Disassembly, Front screen removal: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Front screen removal: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the front screen, I found it to be easier to just pull on the front screen cable and it will pop right out
  16. GoPro Hero 9 and 10 Black Disassembly, Reassembling: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 9 and 10 Black Disassembly, Reassembling: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Follow the steps above in reverse direction for reassembly
    • Apply glue on the borders of the camera as shown in the first picture with red line [Recommended glue: E6000]
    • Recommend you to use some sort of clamp to pressure togather screen and the GoPro frame
    • E6000 ADHESIVE can take anywhere from 24h up to 72h to reach its maximum bond
    • In the second picture you can see how the GoPro looks after
    • Suggested use of waterproof housing if your camera is required to be waterproof
Nemeš
crwdns2935283:007/11/24crwdne2935283:0
619 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 22
crwdns2936753:07crwdne2936753:0 158
crwdns2936753:030crwdne2936753:0 750
crwdns2942667:0crwdne2942667:0 5,248
