GoPro Hero 3 Silver Rear Housing Replacement
  1. GoPro Hero 3 Silver Rear Housing Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver Rear Housing Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. GoPro Hero 3 Silver Rear Housing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery out using the tab.
  3. GoPro Hero 3 Silver Rear Housing Replacement, Rear Housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver Rear Housing Replacement, Rear Housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. GoPro Hero 3 Silver Rear Housing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver Rear Housing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. GoPro Hero 3 Silver Rear Housing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver Rear Housing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. GoPro Hero 3 Silver Rear Housing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver Rear Housing Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. GoPro Hero 3 Silver Rear Housing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In order to replace the buttons. The entire housing has to be replaced.
Brian Alvarez
crwdns2935283:004/02/15crwdne2935283:0
1,439 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-7, Lancaster Spring 2015 crwdns2935289:0Cal Poly, Team 24-7, Lancaster Spring 2015crwdne2935289:0
CPSU-LANCASTER-S15S24G7
crwdns2935297:021crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 2,453
