GoPro Hero 3 Silver LCD Housing Replacement
    1. GoPro Hero 3 Silver LCD Housing Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull back on the tab on the back of GoPro to open the battery cover.
    2. GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the battery out using the tab.
    1. GoPro Hero 3 Silver LCD Housing Replacement, LCD Housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement, LCD Housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the plastic opening tool to remove the faceplate.
      • There is some adhesive and clips so be careful and the faceplate should pop right off.
    2. GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
      • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
    3. GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
      • Using the plastic opening tool, slowly pry open the motherboard assembly.
    4. GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the spudger to gently pry off the connector of the housing to the motherboard.
      • You should now have the motherboard assembly and the housing separated.
    5. GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
      • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
      • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
    6. GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The media adapter is attached to the motherboard via 3 screws:
      • x1 T4 Torx
      • x2 Phillips #00
      • There's a little silver bracket that is held down by the Phillips #00 screw so be careful not to lose it.
      • With a little prying, use the spudger to detach the media adapter's connector from the motherboard.
    7. GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the spudger to lift the black tab up to unlock.
      • Then remove LCD screen connector by sliding out.
    8. GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the Phillips head bit, remove the silver screw near the the top edge of the board.
      • Separate the LCD assembly by pulling away the motherboard.
    9. GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • There are 3 Phillips #00 screws holding the lens onto the LCD housing that need to be removed.
      • Our screw on the top right is stripped, which is why it looks different. However, they will all look the same in your device.
    10. GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver LCD Housing Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully remove the camera lens from the LCD Housing.
      • Now you have the LCD housing removed!
crwdns2935229:05crwdne2935229:0
Brian Alvarez
crwdns2935283:004/02/15crwdne2935283:0
1,439 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-7, Lancaster Spring 2015 crwdns2935289:0Cal Poly, Team 24-7, Lancaster Spring 2015crwdne2935289:0
CPSU-LANCASTER-S15S24G7
crwdns2935297:028crwdne2935297:0
Excellent walkthrough. Thank you Brian!
Nick Goulet - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 9,531
