GoPro Hero 3 Silver Image Sensor Replacement
Jose Villa
crwdns2944107:0crwdnd2944107:0Jose Villacrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 29, 2021crwdne2944111:0
crwdns2931273:0crwdne2931273:0
crwdns2937799:0crwdne2937799:0
  • T4 Torx Screwdriver
    T4 Torx Screwdriver
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
crwdns2944105:0crwdne2944105:0
  1. GoPro Hero 3 Silver Image Sensor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver Image Sensor Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. GoPro Hero 3 Silver Image Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery out using the tab.
  3. GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. GoPro Hero 3 Silver Image Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver Image Sensor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. GoPro Hero 3 Silver Image Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver Image Sensor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. GoPro Hero 3 Silver Image Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver Image Sensor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. GoPro Hero 3 Silver Image Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver Image Sensor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
    • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
  8. GoPro Hero 3 Silver Image Sensor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero 3 Silver Image Sensor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
    • You should now be able to remove the image sensor by simply pulling it.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Jose Villa
crwdns2935283:004/01/15crwdne2935283:0
297 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-7, Lancaster Spring 2015 crwdns2935289:0Cal Poly, Team 24-7, Lancaster Spring 2015crwdne2935289:0
CPSU-LANCASTER-S15S24G7
crwdns2935297:021crwdne2935297:0
After the sensor has been replaced, does the camera need any catibration?
enrilazaro - crwdns2934203:0crwdne2934203:0
Your pictures are really dark.
Nick Ruiz - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,053
