crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace the motherboard in your GoPro Hero+ LCD.
Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
Use the metal spudger to pry around the perimeter of the panel.
Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
Pry around the panel to ensure it is not attached to the device.
Move the panel to the side so you can access the internal components.
Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, peel off the copper tape on the right side of the battery.
Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
Use a pair of tweezers to disconnect the battery connector from the motherboard.
Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
Remove the two 6 mm Phillips #00 screws.
Remove the single 4 mm Phillips #000 screws.
Remove the image sensor from the camera.
Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
Gently lift the microSD/Micro USB assembly up and out of the device.
Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
Remove the three 4 mm Phillips #000 screws securing the motherboard.
Use your fingers to gently remove the ribbon connected to the lens.
Use your fingers and carefully pull out the motherboard from under the lens. It may take a little bit of adjusting to get it out.
