GoPro Hero+ LCD Lens Replacement
    1. GoPro Hero+ LCD Lens Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero+ LCD Lens Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Be sure to power off the GoPro before you start disassembly.
      • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
    2. GoPro Hero+ LCD Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero+ LCD Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the metal spudger to pry around the perimeter of the panel.
      • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
    3. GoPro Hero+ LCD Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero+ LCD Lens Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry around the panel to ensure it is not attached to the device.
      • Move the panel to the side so you can access the internal components.
      • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
    1. GoPro Hero+ LCD Lens Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
      • Be careful of metal contacts on strip; they can be sharp.
    2. GoPro Hero+ LCD Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using tweezers, peel off the copper tape on the right side of the battery.
    3. GoPro Hero+ LCD Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero+ LCD Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
    4. GoPro Hero+ LCD Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a pair of tweezers to disconnect the battery connector from the motherboard.
      • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
    1. GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two 6 mm Phillips #00 screws.
      • Remove the single 4 mm Phillips #000 screws.
    2. GoPro Hero+ LCD Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the image sensor from the camera.
      • You do not have to unplug the black box to remove the USB/SD chip.
    3. GoPro Hero+ LCD Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
      • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
    4. GoPro Hero+ LCD Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift the microSD/Micro USB assembly up and out of the device.
    1. GoPro Hero+ LCD Lens Replacement, Image Sensor: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
      • Do not yank on the image sensor, it can rip out the wiring or damage the motherboard.
    1. GoPro Hero+ LCD Lens Replacement, Motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero+ LCD Lens Replacement, Motherboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero+ LCD Lens Replacement, Motherboard: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the three 4 mm Phillips #000 screws securing the motherboard.
    2. GoPro Hero+ LCD Lens Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your fingers to gently remove the ribbon connected to the lens.
      • Be careful when removing the ribbon cable. Pull off gently or you can separate the ribbon from the contacts.
    3. GoPro Hero+ LCD Lens Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero+ LCD Lens Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero+ LCD Lens Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use your fingers and carefully pull out the motherboard from under the lens. It may take a little bit of adjusting to get it out.
    1. GoPro Hero+ LCD Lens Replacement, Lens: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero+ LCD Lens Replacement, Lens: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero+ LCD Lens Replacement, Lens: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two 4 mm Phillips #000 screws securing the top button.
    2. GoPro Hero+ LCD Lens Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GoPro Hero+ LCD Lens Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 4 mm Phillips #000 screws securing the lens to the case.
    3. GoPro Hero+ LCD Lens Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GoPro Hero+ LCD Lens Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GoPro Hero+ LCD Lens Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently lift the lens up and out of the device.
Matthew Tinkey
crwdns2935283:008/27/15crwdne2935283:0
922 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-4, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 2-4, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S2G4
crwdns2935297:020crwdne2935297:0
I'm curious if you have any suggestions for sourcing the replacement part.
Driftless Repair - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My hing clip is broken, Can I remove the actual camera & replace the full waterproof case then reinstall my camera into the new replacement case ?
jimmac044 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 7,365
