A rhinoceros ate the rear case of your GoPro? No questions here; you can replace it with a new one.
Place your thumb on the indentation in the back case on the side of the GoPro.
Gently press down with your thumb and lift the back cover away from the case to remove it.
Slide a plastic opening tool between the battery and the rear case.
Gently pry the battery up and out of the rear case.
Remove the four Phillips #00 screws securing the rear case to the rest of the device:
Two 5.5 mm coarse thread screws.
Two 4.4 mm fine thread screws.
Slide the edge of a plastic opening tool underneath the sticker on the rear cover and gently peel the sticker up.
Once you have enough of the sticker peeled up with the plastic opening tool, grab an edge of it with your fingers and pull it off completely.
Grasp the rear case and lift it off of the front case.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly.
Use a pair of tweezers to remove the SD board ribbon cable from its connector on the motherboard.
Lift the speaker out of the rear case with the tip of a spudger.
Remove the rear case.
Remove the two 5.8 mm Phillips #00 screws securing the SD board cover to the rear case.
Use the tip of a spudger to push the bottom of the SD board cover up and out of the rear case.
Turn the rear case back over.
Lift the SD board cover out of the rear case with the tip of a spudger and remove it.
Grasp the SD board ribbon cable gently and pull the SD board out of the rear case.
FYI the item that you're disassembling is not the SD card slot, it's the plug for HD Hero accessories such as the Wifi backpack and LCD screen. The SD card is inserted from the side not the back.
