Glass Door Latch Replacement
  1. Glass Door Latch Replacement, Outer Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Glass Door Latch Replacement, Outer Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Glass Door Latch Replacement, Outer Removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #3 screwdriver, unscrew the two 50mm screws on the inner and outer handles.
    • Remove the handles.
  2. Glass Door Latch Replacement, Preparation: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Glass Door Latch Replacement, Preparation: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Glass Door Latch Replacement, Preparation: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the latch key, make sure the key is pointed in the downward position.
    • Insert the second screwdriver or dowel into the bottom hole or latch key hole to prevent the mechanism from falling.
    • The latch mechanism can fall down into the door if the screwdriver/dowel is not inserted.
  3. Glass Door Latch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Glass Door Latch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #3 screwdriver, remove the two 13mm screws from the door while holding the latch.
    • Make sure to hold the latch while unscrewing the mechanism from the door.
  4. Glass Door Latch Replacement, Mechanism Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Glass Door Latch Replacement, Mechanism Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the latch, move the mechanism downwards and remove it from the door.
  5. Glass Door Latch Replacement, Replacement Prep: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Glass Door Latch Replacement, Replacement Prep: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the latch key, put the latch in the lock position.
    • While the mechanism can be installed without the latch being out. Using the latch as a handle will help the installation.
  6. Glass Door Latch Replacement, Installation: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Glass Door Latch Replacement, Installation: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Glass Door Latch Replacement, Installation: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the mechanism top first while holding the latch.
    • Do not let go of the latch until completing Step 7.
  7. Glass Door Latch Replacement, Installation Cont.: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Glass Door Latch Replacement, Installation Cont.: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Glass Door Latch Replacement, Installation Cont.: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #3 screwdriver, screw in the two 13mm screws in the original holes.
    • Remove the screwdriver or dowel from the hole once the mechanism is screwed into the door.
  8. Glass Door Latch Replacement, Latch Correction: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Glass Door Latch Replacement, Latch Correction: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the latch key back into the keyhole.
    • Move the latch key back into the unlocked position.
  9. Glass Door Latch Replacement, Handle Placement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Glass Door Latch Replacement, Handle Placement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Glass Door Latch Replacement, Handle Placement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the handles back into place and screw in the two 50mm screws with a Phillips #3 screwdriver.
    • Make sure the outer and inner handles are aligned. Nothing's worse than a misaligned door handle!
CJ Cummings
crwdns2935283:005/04/20crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
Thank you for sharing this. Btw here is a detailed guide on how to mortise a door latch. In addition to enhancing your practical skills, learning how to mortise a door latch can help you avoid paying a high locksmith fee.
Revolar Revolar - crwdns2934203:0crwdne2934203:0
what brand or manufacturer is this door/lock assembly. im trying to find keyed trim for this
yaakov danzig - crwdns2934203:0crwdne2934203:0
Thank you so much for this post. I was a little nervous about replacing my sliding door lock. Your step by step instructions with pictures made the replacement of my lock so easy.
Dawn - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 91
crwdns2942667:0crwdne2942667:0 8,224
