Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement
  1. Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement, Battery Terminal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement, Battery Terminal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the button labelled glade to open the housing.
    • The inside of the holder has the timer switch and the covering for the inner workings of the holder. For this project, you only need to worry about the battery area located behind the spray.
    • Locate the timer switch and slide it to off.
    • This will prevent any accidental sprays into your face before you remove the spray canister.
  2. Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the spray canister to expose the batteries.
    • Hold the device securely with one hand to prevent any movement.
    • Once the spray canister is removed, you will see the battery compartment exposed, allowing for easy access to the batteries
  3. Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Squeeze and remove the bottom of the front cover. This makes troubleshooting and repairing easier.
    • Pop one side of the hinge from its peg and slightly pull it away from the device.
    • Do the same with the opposite side of the device. Removing the cover will make it easier to work.
  4. Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the batteries to expose the terminals. The terminals are the thin metal pieces that hold the batteries in place.
    • Without the batteries, you can visually assess for problems like loose wires.
  5. Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use small needle nose pliers to gently remove each terminal. Check if any wires are disconnected or loose.
    • The terminals with negative connections (black wires) could have breaks or might have detached from the terminal base. Check for additional issues.
    • The bottom terminal is one piece instead of two pieces like the top ones.
  6. Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the soldering gun and soldering electrical wire to solder the bared wire to the terminal.
    • Align the bared wire with the terminal you intend to solder. Make sure the wire is properly seated against the terminal.
    • Make sure your fingers are a safe distance away from the soldering rod and from the component you are fixing. Use pliers to hold the terminal still.
  7. Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Glade Automatic Spray Holder SJC-180 Battery Terminal Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The solder does not need to be beautiful, just functional.
    • Put the fixed terminal back into the correct place to hold the batteries.
Patricia Reynolds
crwdns2935283:003/24/23crwdne2935283:0
593 crwdns2915208:0crwdne2915208:0
Casper College, Team 5-5, Lareau Spring 2023 crwdns2935289:0Casper College, Team 5-5, Lareau Spring 2023crwdne2935289:0
CASC-LAREAU-S23S5G5
crwdns2942667:0crwdne2942667:0 372
