Just like any other filter, a fuel filter requires replacing after so much use. Rather than paying someone, you can do it yourself with a couple steps and only a filter wrench.
Remove the cover panel from the fuel dispenser.
Using a filter wrench, twist counter-clockwise to remove the old filter.
Once the filter has been removed, place the new filter over the housing and screw clock-wise to install.
After the filter has been installed, reattach the panel cover and lock it in place.
