Gigabyte P34G Solid State Drive Replacement
crwdns2869540:0crwdne2869540:0: 2,4 k
2
16
79
2 352
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:05crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
The solid state drive stores some of the computer's files and has limited space. Replacement of the solid state drive is necessary if it is broken or there is no space left.
Make sure you are grounded before starting. To ground yourself, simply touch a metal object that is in contact with the floor for a few seconds.
    1. Gigabyte P34G Solid State Drive Replacement, Solid State Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
      • There are three different sized screws.
      • x1 9.8mm Screw
      • x8 5.6mm Screws
      • x6 5.0mm Screws
      • Divide the screws by size and save them in a safe space for reassembly later.
    2. Gigabyte P34G Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the marked 4.5mm screw with a #0 screwdriver.
      • Set the screw aside to use for reassembly after replacing the solid state drive.
    3. Gigabyte P34G Solid State Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pull the solid state drive in the direction shown to disconnect it from the port.
yeunghayden
crwdns2935283:005/01/15crwdne2935283:0
841 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-1, Regan Spring 2015 crwdns2935289:0Cal Poly, Team 8-1, Regan Spring 2015crwdne2935289:0
CPSU-REGAN-S15S8G1
crwdns2936753:030crwdne2936753:0 79
crwdns2959996:0crwdne2959996:0 2,352
