Gigabyte P34G RAM Replacement
crwdns2869540:0crwdne2869540:0: 1,6 тыс.
2
18
93
1 583
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:05crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
The laptop uses RAM to read and write data and to perform basic operations. RAM may need to be replaced or added overtime for the laptop to be at optimal performance.
Make sure you are grounded before starting. To ground yourself, simply touch a metal object that is in contact with the floor for a few seconds.
    1. Gigabyte P34G RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the single 9.8mm screw on the underside of the laptop using a #0 screwdriver.
      • Set the screw and cover plate in a safe space for reassembly later.
    2. Gigabyte P34G RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the two marked tabs to the sides to release the RAM.
    3. Gigabyte P34G RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully remove the existing RAM by pulling away from the connector and set it aside.
      • After replacement, remember to re-lock the two white pins to secure the new RAM.
yeunghayden
crwdns2935283:005/01/15crwdne2935283:0
841 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-1, Regan Spring 2015 crwdns2935289:0Cal Poly, Team 8-1, Regan Spring 2015crwdne2935289:0
CPSU-REGAN-S15S8G1
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 93
crwdns2959996:0crwdne2959996:0 1,583
