Gigabyte P34G Battery Replacement
  1. Gigabyte P34G Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all 15 screws on the underside of the laptop using a Phillips #0 screwdriver.
    • There are three different sized screws.
    • x1 9.8mm Screw
    • x8 5.6mm Screws
    • x6 5.0mm Screws
  2. Gigabyte P34G Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4.5 mm screws using a Phillips #0 screwdriver.
    • Save the screws in a safe place for reassembly later.
  3. Gigabyte P34G Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the wires down towards yourself to gently detach the connector from the main drive.
    • Save connector for reassembly later.
  4. Gigabyte P34G Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the battery for removal and discard properly.
    • Replace with new battery.
crwdns2935229:05crwdne2935229:0
yeunghayden
crwdns2935283:005/01/15crwdne2935283:0
841 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-1, Regan Spring 2015 crwdns2935289:0Cal Poly, Team 8-1, Regan Spring 2015crwdne2935289:0
CPSU-REGAN-S15S8G1
crwdns2947412:012crwdne2947412:0
Does anyone know where to find a replacement, or if you can fit the version 1 of this computer with a larger capacity battery from version 2?
tadej rezar - crwdns2934203:0crwdne2934203:0
Over at https://www.mysn.de/detail.asp?bestellnr... (don't mind their stock picture), they still sell the battery for the C404 (which is identical to the P34G v2). I just bought a new 61.25 Wh GNC-J40, manufactured in 2016/07.
M D - crwdns2934203:0crwdne2934203:0
Will it run without the battery or is it a required part of the circuit? I have a P35G V2 and I only use it plugged in anyway.
jens_lipponer - crwdns2934203:0crwdne2934203:0
The battery in my P34G v2 is pretty solidly stuck to the chassis. I don't really want to pull on it too hard but is this normal?
Donald Macaulay - crwdns2934203:0crwdne2934203:0
@jens_lipponer Yes it runs without the battery fine. I have my battery disconnected as it is really swolen and the laptop boots without a problem.
crwdns2942667:0crwdne2942667:0 19,710
