Giant Reign 2 Wheel Spoke Replacement
crwdns2869540:0crwdne2869540:0: 3K
2
17
101
3,013
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2959986:0crwdne2959986:0: 5
crwdns2959982:05crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 20 - 30 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
Have you lost or broken a wheel spoke? This guide will show you how to replace it.
    1. Giant Reign 2 Wheel Spoke Replacement, Hex Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
    2. Giant Reign 2 Wheel Spoke Replacement, Axle Screw: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Giant Reign 2 Wheel Spoke Replacement, Axle Screw: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
      • Push the axle screw to reveal the axle rod on the other side.
    3. Giant Reign 2 Wheel Spoke Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
      • Hold the wheel when pulling out the axle rod so that the bike does not fall.
    4. Giant Reign 2 Wheel Spoke Replacement, Front Wheel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the wheel from the fork.
    1. Giant Reign 2 Wheel Spoke Replacement, Tire Valve: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Giant Reign 2 Wheel Spoke Replacement, Tire Valve: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Giant Reign 2 Wheel Spoke Replacement, Tire Valve: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Twist and pull off the cap covering the tire valve
      • Twist off the spacer that holds the valve in place.
      • Push valve in toward wheel to release air pressure.
    2. Giant Reign 2 Wheel Spoke Replacement, Tire Rim: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Giant Reign 2 Wheel Spoke Replacement, Tire Rim: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Giant Reign 2 Wheel Spoke Replacement, Tire Rim: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert one tire lever between the tire and the rim.
      • Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
      • Insert a second tire lever next to the first.
      • Slowly slide one tire lever around the rim until the tire is released from the rim.
    3. Giant Reign 2 Wheel Spoke Replacement, Tire Tube: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your hand, pull the tube completely out of the tire.
    4. Giant Reign 2 Wheel Spoke Replacement, Brake Rotor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use an 8mm Allen wrench to unscrew the 6 (4x10mm) screws on the brake rotor.
      • Pull brake rotors off both sides of the wheel.
    5. Giant Reign 2 Wheel Spoke Replacement, Tire: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the tire from the rim.
    6. Giant Reign 2 Wheel Spoke Replacement, Rim Tape: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a tire lever, push the rim tape aside to reveal the spoke nipple.
      • Using your fingers, pull off the old spoke nipple.
    7. Giant Reign 2 Wheel Spoke Replacement, Wheel Spoke: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push out the old spoke from the hub.
    8. Giant Reign 2 Wheel Spoke Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Giant Reign 2 Wheel Spoke Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert a new 250mm spoke into the hub.
      • Align the spoke with the spoke nipple in the rim.
      • Try to keep the spoke as straight as possible when threading it around the other spokes. Slight bends will be taken out when it is tightened.
    9. Giant Reign 2 Wheel Spoke Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using an SW-1 spoke wrench, tighten the spoke.
Sterling Grande
crwdns2935283:010/08/12crwdne2935283:0
148 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-14, Amido Fall 2012 crwdns2935289:0Cal Poly, Team 9-14, Amido Fall 2012crwdne2935289:0
CPSU-AMIDO-F12S9G14
crwdns2936753:030crwdne2936753:0 101
crwdns2959996:0crwdne2959996:0 3,013
