Giant Innova Crankset Replacement
  1. Giant Innova Crankset Replacement, Crankset: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement, Crankset: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement, Crankset: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a 5/16" hex key into the pedal axle (on the side of the crankset).
    • Turn the hex key clockwise on the pedal axle until the bolt is completely removed.
    • Pedals can be tight due to thread locking. Apply firm pressure when loosening.
  2. Giant Innova Crankset Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the crank extractor tool into the hole where the pedal axle bolt was.
  3. Giant Innova Crankset Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the front segment of the crank extractor tool (the black part in the photos) clockwise until it is fully threaded into the hole. Use an adjustable or 15 mm wrench for the last couple of turns.
    • Place an adjustable or 15mm wrench on the protruding bolt of the crank extractor, which is the end closest to you.
    • Turn the wrench clockwise to push the crankset off the spindle.
    • Hold onto the pedal for leverage while turning the crank extractor to make removal easier.
    • You can use a hex key to remove the crankset instead.
  4. Giant Innova Crankset Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the old crankset from the chain.
    • Place an adjustable or 15mm wrench on the bolt of the crank extractor.
    • Turn the wrench clockwise to unscrew the crank extractor from the crankset.
  5. Giant Innova Crankset Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a hex key into the pedal axle (on the side opposite of the crankset).
    • Turn the hex key counter-clockwise on the pedal axle until the bolt is completely removed.
  6. Giant Innova Crankset Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the crank-extractor to remove the left pedal using the same procedure as described in step 3.
  7. Giant Innova Crankset Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your new pedal arm on the bare square axle from which you just removed the old pedal arm.
    • Use a hex key to firmly tighten the axle bolt and secure the pedal arm, turning clockwise.
  8. Giant Innova Crankset Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your new crankset on the exposed square axle on the right side of your bike.
    • Ensure your pedal arms face opposite directions.
    • Insert the remaining axle bolt into the center depression of the crankset and use a hex key to tighten. Turn the hex key clockwise until secure.
  9. Giant Innova Crankset Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull your bike's chain over the gears of the crankset, ensuring the teeth and chain are fully interlocked.
    • If you struggle getting your chain around the entire gear, try turning the bike pedal or choosing a smaller gear.
  10. Giant Innova Crankset Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Giant Innova Crankset Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the hole on the end of your pedal arm and begin threading in the bolt at the end of your pedal with your fingers.
    • Once you have tightened the pedal as tight as possible by hand, use an adjustable wrench or 15 mm wrench to finish tightening.
    • Repeat step for right pedal.
Angelo Scalo
crwdns2935283:002/19/25crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
UC Davis, Team 2-8, Andersen Winter 2025 crwdns2935289:0UC Davis, Team 2-8, Andersen Winter 2025crwdne2935289:0
UCD-ANDERSEN-W25S2G8
crwdns2942667:0crwdne2942667:0 128
