Giant Iguana Mountain Bike Front Brake Cable Replacement
  1. Giant Iguana Mountain Bike Front Brake Cable Replacement, Front Brake Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hex screwdriver, loosen this bolt to release the clamp, allowing the brake cable to be removed from the caliper.
  2. Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fixed-length brake cable from its slot.
    • This cable comes out of the left side of the cable splitter, and that is fixed to the cable splitter.
    • Note how the cable runs through the splitter, as you will have to run the new brake cable through in the same manner later.
  3. Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Follow the brake cable to the trigger housing and unscrew the bolt that secures the brake cable to the housing.
  4. Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use needle nose pliers to slide the brake cable from the housing unit.
    • There should be a slot between the housing and associated screw that allows for the cable to slide out.
  5. Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay out the removed brake cable along the new brake cable housing.
    • This will allow you to measure how long you need your new section of cable housing to be.
  6. Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your cable cutters to make a clean cut on the new brake cable housing liner.
    • Ensure your cut is clean to allow the brake cable to pass through easily. A poor cut will have to be redone, making the housing cable shorter.
  7. Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Add your ferrules to the ends of the brake cable housing liner.
  8. Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the new brake cable into the cable housing liner.
    • The side with a cable head will be slotted into the housing unit, while the side ending in just a cable will go down to the caliper by the wheel from step one.
  9. Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slot the new cable head into the opening of the old housing unit.
    • Add the screw removed in step 3 back onto the cable and screw it into the end of the housing unit, ensuring that it is oriented in such a way that the cable will not slide out.
  10. Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When taking the cable from the housing unit to the front brake, pass it through the opening at the base of the stem. Pull the cable through to go down through the splitter.
    • This step will ensure that your cable is taut to provide the necessary tension for functioning.
  11. Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the other end of the cable through the splitter.
    • The new cable will go to the right, which is the side that we removed in step one.
  12. Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The new cable will go to the right side of the wheel, and the fixed side of the splitter will go to the left side of the wheel.
  13. Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the cable tight, and secure it by screwing the bolt tight with the cable under the clamp.
    • Cut it with cable cutters so that there is approximately 2" of extra cable length left over.
  14. Giant Iguana Mountain Bike Front Brake Cable Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Add a cap to the end of the newly cut brake cable, and secure the cap by clamping it firmly with your pliers.
    • This will prevent the cable from fraying.
Christian Garcia
crwdns2935283:010/23/24crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 3-42, Harris Fall 2024 crwdns2935289:0CSU Los Angeles, Team 3-42, Harris Fall 2024crwdne2935289:0
CSULA-HARRIS-F24S3G42
crwdns2942667:0crwdne2942667:0 128
