GermGuardian AC4825E UV-C Bulb Replacement
  1. GermGuardian AC4825E UV-C Bulb Replacement, HEPA Filter Unit: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check if the purifier's power cord is plugged into an electrical outlet.
    • If it is plugged in, unplug the power cord.
  2. GermGuardian AC4825E UV-C Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GermGuardian AC4825E UV-C Bulb Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the rear cover of the purifier with one finger on the Lock and Release button.
    • Press the button down, and pull the rear cover away from the purifier.
  3. GermGuardian AC4825E UV-C Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GermGuardian AC4825E UV-C Bulb Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GermGuardian AC4825E UV-C Bulb Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands to pull the HEPA filter out of the purifier.
    • After reassembly, push & hold the UV control button for 5 seconds to reset the filter change indicator.
  4. GermGuardian AC4825E UV-C Bulb Replacement, UV-C Bulb: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws from the metal UV-C shield by turning the screws counter-clockwise using a Phillips #00 screwdriver.
    • Grab and pull the UV-C shield away from the purifier to remove it.
  5. GermGuardian AC4825E UV-C Bulb Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GermGuardian AC4825E UV-C Bulb Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GermGuardian AC4825E UV-C Bulb Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a tissue or a clean cloth, reach into the exposed space and grab the UV-C bulb.
    • Pull the UV-C bulb out of the exposed space to remove the bulb from its socket.
    • After reassembly, press and hold the UV control button for 5 seconds to reset the UV bulb change indicator.
Tim Lourenco
crwdns2935283:003/28/22crwdne2935283:0
329 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-1, Mellen Spring 2022 crwdns2935289:0UMass Dartmouth, Team 2-1, Mellen Spring 2022crwdne2935289:0
UMASSD-MELLEN-S22S2G1
you end after you pull the bulb out. do you put another bulb in (of course) is there a right/wrong way (which side up or down) then do you plug it back in prior to holding the uv button 5 seconds? do you turn it on prior to holding the uv button 5 seconds? Please explain in detail what I should do.
william estes - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 2,811
