Use this guide to replace the upper feed roller bearing in a General Pipe Cleaners Drain Cleaner PMEBO 2016.
Use your hand to unscrew and remove the feed pressure knob.
Use a 1/4 inch socket wrench to remove the three bolts securing the feed roller holder plate.
Use a 3/16 inch hex wrench to remove the top swing pin.
Use pliers to lift out and remove the pressure spring plate.
Lift out and remove the pressure spring.
Use pliers to lift the top carrier straight up and out of the feed body.
Use a 3/16 inch hex wrench to remove the feed roller shaft.
Remove the upper feed roller assembly, including the fiber disks on either side of it.
