General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement
  1. General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement, Reverse Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, make sure the drain cleaner is disconnected from power.
    • Use a Phillips #2 driver to remove the two screws securing the control box cover.
  2. General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the control box cover.
  3. General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 9/16 inch deep socket and ratchet to remove the nut securing the reverse switch.
  4. General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the reverse switch guard.
  5. General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze the tabs on either side of the reverse switch connector.
    • Pull the two halves of the connector apart to disconnect it.
    • Take note of where everything is connected in the control box before disconnecting anything else.
  6. General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the white cable straight off of its spade connector on the power switch diaphragm.
  7. General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the black cable straight off of its spade connector on the power switch diaphragm.
  8. General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the switch assembly down out of its hole in the control box and pull it out of the control box.
    • Be careful not to snag the switch on any cables during removal.
  9. General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement, Power Cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement, Power Cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement, Power Cable: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push in on the small tab on the side of the plastic power cable clip.
    • While holding the tab down, pull straight down on the power cable.
    • Do not remove the cable yet, it is still connected to the drain cleaner. Slide it down just enough to move the clip out of the control box.
  10. General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to loosen the two screws securing the power box cover.
    • With the screws loose, slide the bottom of the cover to the right enough so the whole cover can swing down and away from the box opening.
  11. General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a flathead screwdriver to remove the green screw securing the green power cable wire.
  12. General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use pliers to pull the white power cable straight off of its spade connector.
  13. General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 General Pipe Cleaners Drain Cleaner PMEBO 2016 Power Cable Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Feed the green power cable wire through the control box first, then carefully pull down on the entire power cable and remove it.
    • Make sure you don't snag the power cable on any wires or on the control box during removal.
    • During reassembly, feed the white wire through the control box and into the power box first, then the green wire.
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
212,875 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,632
