Use this guide to replace the lower feed roller bearing in a General Pipe Cleaners Drain Cleaner PMEBO 2016. There are two lower feed roller bearings—this guide only shows removal of only one of them. To remove the other, follow this procedure for the other side.
Use a 1/4 inch socket wrench to remove the three bolts securing the cable adjustment plate.
Use a 3/16 inch hex wrench to remove the swing pin.
Pull the thrust bearing straight out and remove it.
Use pliers to slide the bottom carrier straight out of the feed body.
Use a 3/16 inch hex wrench to remove the feed roller shaft.
Remove the upper feed roller assembly, including the fiber disks on either side of it.
crwdns2917034:0crwdne2917034:0
If you feel that simply opening/cleaning the drain will suffice, that's your choice. If you really want to make sure your drain is cleaned and cleared of all debris, you may want to spend a little extra for thorough results. Better care. Better value. Better results. Call a plumber drain at Curtis Plumbing FL today to avoid major problems in the future.
