Use this guide to replace the motor assembly in a General Pipe Cleaners Drain Cleaner EJB 2014.
Loosen the belt guard knob enough to be able to slide the belt guard toward the front of the drain cleaner.
Slide the belt guard toward the front of the drain cleaner and off of the motor.
Push down on the motor to take tension off of the belt.
Lift the belt off of the motor pulley and remove it from the motor.
Use two 1/2 inch wrenches to remove the four nut and bolt sets securing the motor to the drain cleaner.
