GeeksPhone Keon Screen Replacement
  1. GeeksPhone Keon Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GeeksPhone Keon Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
  2. GeeksPhone Keon Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the cover away from the phone.
  3. GeeksPhone Keon Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
  4. GeeksPhone Keon Screen Replacement, Back Plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GeeksPhone Keon Screen Replacement, Back Plate: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
  5. GeeksPhone Keon Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GeeksPhone Keon Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the small orange plate by pulling it down.
  6. GeeksPhone Keon Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
  7. GeeksPhone Keon Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GeeksPhone Keon Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GeeksPhone Keon Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
  8. GeeksPhone Keon Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GeeksPhone Keon Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the backplate away from the device.
  9. GeeksPhone Keon Screen Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GeeksPhone Keon Screen Replacement, Motherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three connections from the back of the motherboard by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    • Remove the wire from the bottom left of the motherboard by lifting it away from the device.
    • Remove the 2mm T3 screw in the upper left corner of the motherboard.
  10. GeeksPhone Keon Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard and remove the connector on the back by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
  11. GeeksPhone Keon Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard from the device.
  12. GeeksPhone Keon Screen Replacement, Antenna: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unfasten the black wire from the metal clamps by hand and lift the black wire away from the device.
    • Unfasten the plastic clamps attached to the antenna.
  13. GeeksPhone Keon Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GeeksPhone Keon Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GeeksPhone Keon Screen Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the antenna and flip it over to reveal a ZIF connector on the back.
    • Flip up the small retaining flap on the ZIF connector and pull the ribbon cable out.
  14. GeeksPhone Keon Screen Replacement, Screen: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GeeksPhone Keon Screen Replacement, Screen: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to gently lift up the back of the screen.
  15. GeeksPhone Keon Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GeeksPhone Keon Screen Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue to lift up the screen until it is loose from the device.
DavidDrash
crwdns2935283:008/26/15crwdne2935283:0
263 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-5, Eyestone Fall 2015 crwdns2935289:0USF Tampa, Team 3-5, Eyestone Fall 2015crwdne2935289:0
USFT-EYESTONE-F15S3G5
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 216
