GeeksPhone Keon Battery Replacement
  1. GeeksPhone Keon Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GeeksPhone Keon Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
  2. GeeksPhone Keon Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the cover away from the phone.
  3. GeeksPhone Keon Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
Yanni Worthington
crwdns2935283:008/26/15crwdne2935283:0
325 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-5, Eyestone Fall 2015 crwdns2935289:0USF Tampa, Team 3-5, Eyestone Fall 2015crwdne2935289:0
USFT-EYESTONE-F15S3G5
Newer Keon model has user replaceable battery GP-BA002
gintasdx - crwdns2934203:0crwdne2934203:0
Newer Keon model has a user replaceable battery Li-ion GP-BA002 3.7V 1580mAh .
GP-BA002: Li-ion, 3.7V ,1580mAh, Limited charge voltage 4.2v, with dimensions: 5.1x5.1x0.5cm, its a four pin battery, the pinout es: Negative, BSI, BTemp, Positive, both negative and positive al labeled on the front of the batery the other two not, BTemp is a 10k oms resistor and BSI reads 47k oms on a discharged battery
Diego Gomez - crwdns2934203:0crwdne2934203:0
Has anybody found another battery that is compatible with the GP-BA002?
ecloud - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 707
