If you are having issues with battery life or charging, use this guide to replace the battery.
Insert the plastic opening tool into the seam between the front of the device and the rear cover.
Slide the plastic opening tool from the bottom of the phone to the top.
Use the plastic opening tool to free all the clips attached to the phone.
Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
Lift the battery with the plastic opening tool and finish removing battery by hand.
Newer Keon model has user replaceable battery GP-BA002
Newer Keon model has a user replaceable battery Li-ion GP-BA002 3.7V 1580mAh .
GP-BA002: Li-ion, 3.7V ,1580mAh, Limited charge voltage 4.2v, with dimensions: 5.1x5.1x0.5cm, its a four pin battery, the pinout es: Negative, BSI, BTemp, Positive, both negative and positive al labeled on the front of the batery the other two not, BTemp is a 10k oms resistor and BSI reads 47k oms on a discharged battery
Has anybody found another battery that is compatible with the GP-BA002?
