If the back plate of your Keon is damaged or broken, use this guide to replace the back plate.
Insert the plastic opening tool into the seam between the front of the device and the rear cover.
Slide the plastic opening tool from the bottom of the phone to the top.
Use the plastic opening tool to free all the clips attached to the phone.
Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
Lift the battery with the plastic opening tool and finish removing battery by hand.
Remove the two 5mm T4 screws on the sides of the small orange plate.
Gently remove the small orange plate by pulling it down.
Remove the following screws securing the back plate to the device:
Two silver 2mm T3 screws
Five black 3mm T3 screws
Slightly lift up the bottom corner of the backplate.
Release the four clips on both sides by pulling them away from the device.
Lift the backplate away from the device.
