Geberit toilet flush (old model) replacement of the seal
  1. Geberit toilet flush (old model) replacement of the seal, Remove cover (flush-mounted model): crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Geberit toilet flush (old model) replacement of the seal, Remove cover (flush-mounted model): crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Geberit toilet flush (old model) replacement of the seal, Remove cover (flush-mounted model): crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift pressure plate from bottom to top, then remove
    • first unscrew the outer frame
    • then the inner cover. Carefully pull away to the front.
  2. Geberit toilet flush (old model) replacement of the seal, Surface model: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab left and right and pull up quite vigorously.
  3. Geberit toilet flush (old model) replacement of the seal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to turn off the water inlet, e.g. at this corner tap.
  4. Geberit toilet flush (old model) replacement of the seal, The valve: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Geberit toilet flush (old model) replacement of the seal, The valve: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The filling valve. Photo 1 with the surface box.
    • Photo 2 shows the valve in the flush-mounted box.
  5. Geberit toilet flush (old model) replacement of the seal, Disconnect water inlet: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a water pump pliers, you loosen the union nut on the valve. So it is separated from the water inlet.
    • Remove the hose slowly so that no part falls out.
  6. Geberit toilet flush (old model) replacement of the seal, Lift out the valve: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the surface-mounted box you can simply push the valve upwards.
    • For the in-wall box, lift the valve up and set it aside. Then unscrew the top part until the float comes loose.
    • Now you can lift out the parts.
  7. Geberit toilet flush (old model) replacement of the seal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here you can see the parts of the valve. The seal is the red dot!
  8. Geberit toilet flush (old model) replacement of the seal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Geberit toilet flush (old model) replacement of the seal: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now the seal has to be removed and replaced. It is sometimes difficult to find out. Try a small screwdriver.
    • Figure 2 shows a defective seal (here black). Clearly a ring is pressed into it.
    • If the seal is still elastic, you can just flip it over. A new seal is really not expensive.
  9. Geberit toilet flush (old model) replacement of the seal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When reassembling you have to make sure that the release lever engages correctly again. Use a screwdriver if necessary.
Repeat the steps in reverse order to reassemble your device.
crwdns2935229:011crwdne2935229:0
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
291,001 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
crwdns2947412:07crwdne2947412:0
I don’t like Geberit toilet. My all time favorite flushing toilet is American standard https://bestflushingtoilet.org/american-.... Really, I like this brand flushing technology.
zukond - crwdns2934203:0crwdne2934203:0
That’s a great effort to share information about the Geberit toilet, but I think most people do not use these toilets. Here https://lueliving.com/ is a list of some best toilest. I’m sure that will be helpful.
jana - crwdns2934203:0crwdne2934203:0
In Europe, Geberit is very popular, and it is one of the few brands that provides parts/upgrades for older models (even going back to 1964, when they started).
Tom Verhoeff - crwdns2934203:0crwdne2934203:0
Super mega klasse danke für die Anleitung hilft ungemein
Uwe Häcker - crwdns2934203:0crwdne2934203:0
Danke! Dichtung umgedreht und alles funktioniert wieder. Bester Tipp. Ich bin ganz glücklich (und stolz, dass ich die Spülung allein repariert habe).
Dorle - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 112
crwdns2936753:07crwdne2936753:0 970
crwdns2936753:030crwdne2936753:0 3,786
crwdns2942667:0crwdne2942667:0 123,707
