Geardup RC Ford Mustang GT Motor Replacement Guide
  1. Geardup RC Ford Mustang GT Motor Replacement Guide, Battery Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Geardup RC Ford Mustang GT Motor Replacement Guide, Battery Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Geardup RC Ford Mustang GT Motor Replacement Guide, Battery Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 5mm Phillips #0 screw from the bottom of the car, located between the rear wheels.
    • Gently lift the battery cover from the car to expose the batteries.
  2. Geardup RC Ford Mustang GT Motor Replacement Guide, Lower RC Car: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Geardup RC Ford Mustang GT Motor Replacement Guide, Lower RC Car: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the car over and remove the four 5mm Phillips #0 screws that hold the shell to the car chassis.
  3. Geardup RC Ford Mustang GT Motor Replacement Guide, Shell: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the car over again to its upright position and vertically lift the shell from the car.
    • During re-assembly, make sure the shell is correctly aligned. If it is not aligned correctly, it may rub on the wheels, possibly preventing them from turning.
  4. Geardup RC Ford Mustang GT Motor Replacement Guide, Rear Wheels: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Geardup RC Ford Mustang GT Motor Replacement Guide, Rear Wheels: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew and remove the 5mm Phillips #0 screw located at the center of the wheel while holding the wheel still.
    • Slide the wheel off of the axle.
    • Repeat the previous steps for the other rear wheel.
  5. Geardup RC Ford Mustang GT Motor Replacement Guide, Motor/Circuit Board Enclosure: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Geardup RC Ford Mustang GT Motor Replacement Guide, Motor/Circuit Board Enclosure: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 5mm Phillips #0 screws located on the top of the motor/circuit board enclosure.
    • Vertically lift the motor/circuit board enclosure from the car chassis.
  6. Geardup RC Ford Mustang GT Motor Replacement Guide: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Geardup RC Ford Mustang GT Motor Replacement Guide: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small plastic opening tool, gently pry the clips to release the tabs on the circuit board casing. The clips can be located above where the rear wheels used to be.
    • Lift the clips just enough to release them from the tabs. If they are pried too far, they may snap off.
    • There is a clear gear grease inside the enclosure.
  7. Geardup RC Ford Mustang GT Motor Replacement Guide: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Geardup RC Ford Mustang GT Motor Replacement Guide: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the circuit board casing from the enclosure to reveal the motors, gears, and circuit board.
    • During re-assembly, make sure the wires are not pinched between plastic dividers in the enclosure as this may damage them.
  8. Geardup RC Ford Mustang GT Motor Replacement Guide, Motor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the copper solder wick, remove the solder from the two wires at the points where they connect to the motor.
Matthew Seno
crwdns2935283:002/01/15crwdne2935283:0
191 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-38, Amido Winter 2015 crwdns2935289:0Cal Poly, Team 8-38, Amido Winter 2015crwdne2935289:0
CPSU-AMIDO-W15S8G38
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 507
