Gateway Solo 1200 Keyboard and Frame Replacement
  1. Gateway Solo 1200 Keyboard and Frame Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Keyboard and Frame Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Keyboard and Frame Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
  2. Gateway Solo 1200 Keyboard and Frame Replacement, Keyboard and Frame: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway Solo 1200 Keyboard and Frame Replacement, Keyboard and Frame: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device so the back is facing you.
    • Unscrew the 2 mm screws with a Phillips #0 screwdriver.
    • Unscrewing these back screws partially releases the keyboard.
  3. Gateway Solo 1200 Keyboard and Frame Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway Solo 1200 Keyboard and Frame Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open up the device so the keyboard is visible.
    • Locate the front panel with the power button above the keyboard.
    • Remove the panel by gently pulling on it.
    • The panel should pop out with little force.
  4. Gateway Solo 1200 Keyboard and Frame Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Keyboard and Frame Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Keyboard and Frame Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the keyboard panel up.
    • Flip the keyboard panel over to reveal the underside.
    • Gently tug on the ribbon cable at the bottom of the keyboard panel to release the keyboard.
  5. Gateway Solo 1200 Keyboard and Frame Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Keyboard and Frame Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Keyboard and Frame Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove both monitor hinge covers at the base of the screen by unscrewing the 2 mm screws with a Phillips #0 screwdriver.
    • Locate the visual output cord on the exposed left hinge connecting the monitor to the laptop.
    • Gently tug on the visual output cord to remove the screen.
  6. Gateway Solo 1200 Keyboard and Frame Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Keyboard and Frame Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Keyboard and Frame Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the screen is removed, locate the keyboard frame screws.
    • Unscrew the outer frame and gently pull it away from the device.
    • Gently tug on the trackpad connector underneath the keyboard frame to completely remove it.
Riki
crwdns2935283:008/26/19crwdne2935283:0
235 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S1-G3, Friess Fall 2019 crwdns2935289:0University of North Texas, Team S1-G3, Friess Fall 2019crwdne2935289:0
UNT-FRIESS-F19S1G3
crwdns2935297:038crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 373
