Gateway Solo 1200 Fan Replacement
    1. Gateway Solo 1200 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Turn off your laptop and disconnect it from AC Adapter before use.
      • Locate the battery latch on the bottom of the laptop.
      • Release the latch by pressing it with your thumb and sliding it to the right.
      • Slide the battery out of its compartment.
      • Discharge your laptop by pushing the power button after removing the battery.
    1. Gateway Solo 1200 Fan Replacement, Keyboard and Frame: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway Solo 1200 Fan Replacement, Keyboard and Frame: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the device so the back is facing you.
      • Unscrew the 2 mm screws with a Phillips #0 screwdriver.
      • Unscrewing these back screws partially releases the keyboard.
    2. Gateway Solo 1200 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway Solo 1200 Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Open up the device so the keyboard is visible.
      • Locate the front panel with the power button above the keyboard.
      • Remove the panel by gently pulling on it.
      • The panel should pop out with little force.
    3. Gateway Solo 1200 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Fan Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently lift the keyboard panel up.
      • Flip the keyboard panel over to reveal the underside.
      • Gently tug on the ribbon cable at the bottom of the keyboard panel to release the keyboard.
    4. Gateway Solo 1200 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove both monitor hinge covers at the base of the screen by unscrewing the 2 mm screws with a Phillips #0 screwdriver.
      • Locate the visual output cord on the exposed left hinge connecting the monitor to the laptop.
      • Gently tug on the visual output cord to remove the screen.
    5. Gateway Solo 1200 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Once the screen is removed, locate the keyboard frame screws.
      • Unscrew the outer frame and gently pull it away from the device.
      • Gently tug on the trackpad connector underneath the keyboard frame to completely remove it.
    1. Gateway Solo 1200 Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the heatsink next to the fan.
      • Unscrew the four 2mm screws attaching the heatsink to the device.
      • Lift the heatsink upwards, careful not to disturb other internal components.
    2. Gateway Solo 1200 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway Solo 1200 Fan Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the four screws attaching the fan to the device.
      • Carefully tug the fan's connector from the heat system.
      • The connector is fragile and shouldn't be yanked to avoid damages.
Riki
crwdns2935283:008/26/19crwdne2935283:0
235 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S1-G3, Friess Fall 2019 crwdns2935289:0University of North Texas, Team S1-G3, Friess Fall 2019crwdne2935289:0
UNT-FRIESS-F19S1G3
crwdns2935297:0240crwdne2935297:0
crwdns2942667:0crwdne2942667:0 542
