Gateway SA1 RAM Replacement
    1. Gateway SA1 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Move the latch to the right of the battery to unlock.
    2. Gateway SA1 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
      • The latch must be held in position to remove the battery.
    1. Gateway SA1 RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway SA1 RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Loosen the indicated Philips screw that connects the memory bay cover to the casing.
      • The indicated Philips screw does not come out of the cover.
    2. Gateway SA1 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway SA1 RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift and remove the cover using the spudger.
    3. Gateway SA1 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway SA1 RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently press the clip outwards.
      • The module will tilt up and can be pulled out of the slot.
      • There may be another memory module underneath so be sure to remove both.
    4. Gateway SA1 RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • To insert a new memory, slide the module into the slot at a 30 to 45 degree angle.
      • Place the first module into the bottom slot then the next module into the top slot.
      • These slots are keyed so verify that you are sliding the module in one direction.
      • Verify that the new memory modules are designed for your specific Gateway Laptop.
Diego Carteno
crwdns2935283:004/15/10crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-20, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 24-20, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S24G20
crwdns2935297:084crwdne2935297:0
crwdns2936753:030crwdne2936753:0 108
crwdns2942667:0crwdne2942667:0 6,245
