crwdns2942287:0crwdne2942287:0 ↓The keyboard is a component that will allow you to type and input commands on your device. This guide will go over how to remove and replace the keyboard for the P-6831FX.
Open your laptop and lay it flat
Locate the speaker grill/interaction bar.
Remove the speaker grill/interaction bar by pulling up at both edges.
Detach the two ribbon cables on the underside of the keyboard.
Remove the five Philips #0 (3mm) screws securing the keyboard in place.
Pull the keyboard up and away from you.
Remove the ribbon cable attached underneath to the keyboard.
