Does your computer die sooner than it did when you bought it? You may need to replace your battery as it might be damaged. This step-by-step guide will show you how to quickly and safely replace your battery for your Gateway NV59C66u laptop.
First turn off your laptop, close it, then turn your laptop over exposing the bottom side.
Locate the Latches below the battery.
Slide the vertical latch upward, unlocking the battery
Slide the horizontal latch to the right so you are able to remove the battery from the bottom of your laptop.
Now the battery is free. Proceed to lift and remove the battery.
Place the old batter to the side, as to not get it confused from your new battery you intend to install.
Take your new battery and position it into the battery slot you took the old one out of.
Make sure latches are in the unlocked position and apply light pressure on the new battery to make sure it is in place.
Put latches in lock position and turn laptop over.
